Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
ryan (guest)
Guest
Posts: n/a
Does your bearing work in the 2005 boxster 987?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Intermediate Shaft Bearing Replacement and Upgrade (IMS) - 986 Boxster (1997-04) - 987 Boxster (2005-06)
Old 06-15-2012, 12:28 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
CEO, Pelican Parts Inc.
Wayne at Pelican Parts's Avatar
It should, but the crossover to the bigger sized bearing occurred somewhere in that year range, so I suggest you take a look.
- Wayne
Wayne R. Dempsey, CEO, Pelican Parts Inc., and Author of:
101 Projects for Your BMW 3-Series101 Projects for Your Porsche 911How to Rebuild & Modify Porsche 911 Engines101 Projects for Your Porsche Boxster & Cayman
Coming in 2012:
• 101 Projects for Your MINI Cooper • 101 Projects for Your Porsche 996 / 997
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
feelyx's Avatar
I have designed a replcement shaft insert that removes the bearing from the shaft to the case. The shaft insert will insert down the center of the shaft and is a inteference fit. You leave the outer race of the bearing in place as you cannot pull it out anyways. When you tighten the allan screw in the shaft insert it spreads 3 locking rings into the original bearing race locking the shaft in place. It is just in the drawing phase but hopefully soon to have a working model. Unfortuneately you have to destroy the original bearing to install this idea, because you can't remove the bigger bearing. But, you get have an oiler lube a new bearing that is repaceable and it removes the flex point from inside the shaft to the case.
This sent from my phone so spelling might be way off and its hard to see what i am typing.
98 Boxster
87 560sl
04 S2000
Old 06-15-2012, 01:19 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
You can't generalize about '05 motors as there were 2 revisions of the IMS design used. In the beginning of the build cycle, the '04 design was still being used. Sometime in the middle of the year, Porsche started to use the same design they would use on the '06-08 cars. And you can't tell without pulling the transmission off the engine and inspecting the IMS housing. No way of determining by engine serial number that anyone has posted.
Old 06-16-2012, 06:59 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
