Unhappy OH BOY......Smoke
2001 Starting to smoke on start up. It does not do it all the time. Are you thinking what I am? This is weird bought the car and it was leaking oil. Now it quit leaking and has a plum of smoke out the tail pipes when you start it. But not every time. I have ran it hard then start it the next morning to see if that is it. Sometimes it does and sometimes it doesnt. Then today I started it no smoke moved it 50 yards started it a few hours later and holy hell .... lots of smoke. What is going on? Anyone out there know?
Trace
Old 06-29-2012, 06:16 PM
bar10dah's Avatar
Yes, I know what's going on. You own a Boxster.
Old 06-29-2012, 07:29 PM
Inquisitive user
randy_k's Avatar
Trace
First guss is the AOS. after that. Just more guesses. It's all pretty much a guess. And like Keith said. Yes you own a Boxster.
Randy
Perpetual change. It will happen!!!
Old 06-29-2012, 08:06 PM
j911brick's Avatar
How many miles on the car? Have you ever had an oil analysis done?
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 06-29-2012, 10:57 PM
s_wilwerding's Avatar
It's almost certainly the AOS - I had the same symptoms. You could pull off the intake tube and see if there is oil in there - that is a dead giveaway.
Steve Wilwerding
1998 3.4L Zenith Blue Boxster
2009 Meteor Gray Cayenne
Old 06-30-2012, 06:19 AM
haycait911's Avatar
I have a similar problem. what's an AOS?
Old 06-30-2012, 09:58 AM
Inquisitive user
randy_k's Avatar
Air Oil Separator
http://www.pelicanparts.com/techarticles/Boxster_Tech/09-ENGINE-Air_Oil_Separator/09-ENGINE-Air_Oil_Separator.htm
Old 06-30-2012, 10:52 AM
Thanks I will take a look.
Old 07-01-2012, 11:24 AM
Zeke's Avatar
Or you could remove the oil fill cap and if there is a LOT of suction while running, that's the main symptom.
Old 07-02-2012, 10:22 AM
