Artic99 (guest)
Guest
Posts: n/a
What is the transmission shaft front bearing supposed to look like the bearing in the bell housing when you remove the support tube? Mine had a flat metal ring that basically fell out, and only has 8 or so ball bearing on the bottom half of the circular bearing - the top half of the bearing does not contain ball bearings. Is this an issue?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Clutch Replacement - 986 / 987
Old 07-18-2012, 07:54 PM
transmission main bearing
picture of the main transmission shaft bearing (behind the throw-out bearing support tube).
Does this look like a good bearing?
Old 07-19-2012, 06:51 AM
feelyx's Avatar
That bearing is destroyed... there should be a cage holding the balls equal distance apart.. You will have to replace it. Besure to find all the bits and pcs. you can.
98 Boxster
87 560sl
04 S2000
Old 07-19-2012, 07:26 AM
looks like that bearing caught the IMS virus!
Old 07-19-2012, 07:59 PM
Author of "101 Projects"
Wayne 962's Avatar
Yes, from the fuzzy photo, it looks pretty terrible. I've never really seen anything that bad in that area, which leads me to believe that something else caused this to happen. This is a sealed bearing, I believe, so oil / fluid starvation should not be an issue.
Hmm...
-Wayne
Old 07-19-2012, 11:20 PM
i had a similar unexplained failure on a 914 years ago
Old 07-20-2012, 01:38 PM
