What warning is "limit 10" inside circle?
08 Boxster with Tip.
Put new tires on recently. Had two pressure sensor fail (supposedly). Finally got them to read. Now I have a warning after every stop of "limit 10" inside of a circle on the instrument face? Any ideas? Dana |
Iirc there is a setting which you can set in the cluster to chime at you if you hit a certain speed......sounds like that......
Use the menu selector switch on the steering column syalk and raise the limit and see if that's it... |
Thanks bell.
Just figured it out. I deactivated it. |
This has got to be one of the most commonly asked questions. On the early cars, the thing just chimes at you with no display, so people keep wondering what that's for. Some people take years to figure it out!
-Wayne |
| All times are GMT -8. The time now is 08:16 PM. |
