Good dino oil for a boxster with 135k miles
Please recommand a type of good dino oil for a boxster with 135k miles. I was using mobile 1 high mileage, but heard syn oil is bad for old seals....I plan to change oil every 3500 miles .. is it too frequent? I live in South Carolina, is 10w 40 Ok for autumn use?
3500 miles might be too frequent, it really depends on time. If you are driving 3500 miles a year, it is a good change interval. I drive about 3500 miles every 3 months, so it would be a waste of resources for me. I recommend starting at the recommended change interval and pulling samples when you change it. Blackstone Labs is well regarded as an oil test facility and their prices are reasonable. You can use the info they provide to decide if changing the interval makes sense or not. Blackstone Labs, no interest other than as a satisfied customer, etc etc
Tom Coradeschi 03 Boxster |
Second, there is no "dino" oil that can hold a candle to the heat transfer, lubricity, detergency, and long life under high heat/high shear properties of a full synthetic, unless you go to a "boutique" specialty oil, which ends up costing even more the synthetic.
Accrochez-vous bien de vos rêves..........." |
The urban legend about synthetic causing leaks also only applied to engines which were originally running dino juice. If the engine has always run synthetic then there is certainly no problem. My Benz E320 is now 10 years old and has 155k on it. Each and every one of those miles have been run with synthetic and the car does not leak a drop of oil. I am sure my 987 will be the same way as its miles add up.
2006 Boxster S 2008 Mini Cooper S 2002 Mercedes Benz E320 Wagon 1985 Toyota Supra (my sons) |
Burn the fire.
Keep running Mobile 1 as recommended. If anything run a bottle or two of the Swepco Oil Improver that our host sells to add in a good dose of necessary anti-wear agents and you should be more than fine.
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
