Safe Driving and KIA flathead
Hello Everyone,
I replaced the ignition switch today and unfortunately dropped a small metal screw driver into the left front wheel-well under the dash..seems to be behind the fuse box.
Any concerns with safe car use if left alone? Recommendations on retrieving the screwdriver? Get a gigantic magnet?!
Thank you for reading,
Ben
Old 01-15-2013, 02:52 PM
2001 Boxter S
first, no worries.
the screwdriver will not hurt anything so you can leave it there if you want.
on the other end, the fuse box is very easy to remove from its place.
just move it aside and see if you can find the screwdriver. you can also use a flexible magnet to retrieve it.
something like that:
18" Flexible Magnetic Pick Up 2 lb Capacity Soft Grip Handle | eBay
it doesn't need to be gigantic, just insert the magnet from the same spot you doped the screwdriver.
good luck.
Old 01-15-2013, 03:46 PM
Thank you!
Old 01-15-2013, 04:09 PM
