Boxster spark plugs
The dealer wants $550 to change the spark plugs on my '05 Boxster S. Has anyone done that? Is it a big deal? I'm thinking of doing it myself. Don't care how long it takes just if it is doable.
Pelican Technical Article: Replacing Boxster Spark Plugs and Coils - 986 / 987 |
Inquisitive user
Took me and a buddy of mine a little over an hour. No big woo.
Randy
Perpetual change. It will happen!!! |
I'm doing mine next weekend. Looks pretty straight forward.
1985 Triple Black Cabriolet-ROW**Sold** 2008 Cayman S Guards Red/Black 2007 Audi A4 2.0T Red/Black |
If you are doing the tubes also, try a 3/4" threaded pipe nipple and cap from lowes or home depot to extract them. The pipe nipple screws in and then you can pry out the tube.
I tried several other online methods of extracting the tubes without much success. |
one of gods prototypes
I have a special tool that I made to pop tubes out.....buyer :-)
Brought to you by Carl's Jr. |
The OP has an 05, should be no need to touch the tubes on that car. Job is way easy, especially if you take off the rear tires.
Tom Coradeschi 03 Boxster |
Thanks everyone - I'll tackle it!
93, do you have a pic of what you are talking about...going to tackle this next so until I see the tubes it's hard to visualize.
No tubes after 2003:..no need to worry unless you want to remove the whole cam cover! Good luck!
they sell this at lowes or home depot in the iron pipe section. The 3/4 in size worked perfectly for me. You can screw it into the tube and then easily pull the tube out without worrying that it will break. ![]() |
Thank you.
