-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Any idea what this connector is for ??? (http://forums.pelicanparts.com/boxster-cayman-forum/712486-any-idea-what-connector.html)
pbkirby 10-21-2012 07:17 AM
Found it in the shifter console. the following numbers where listed 1-929 529, AMP 1-828 8191, BMW 1-378 134.http://forums.pelicanparts.com/uploa...1350829063.jpg
JFP in PA 10-21-2012 07:31 AM
Factory cell phone...............
s_wilwerding 10-22-2012 05:09 AM
The nice thing is that, if you want to integrate your garage door opener or another accessory, you can pull 12 V constant and switched power off of that plug. I added a garage door opener button to my center console using that for switched power.
pbkirby 10-25-2012 09:08 AM
Any idea where I can find a wiring diagram for this connector
Looking to find the power and ground, may use for my next sat radio install.
tcora 10-26-2012 05:12 AM
Where was it? Did you have to pull the entire console to get at it? Be nice to know if it's switched 12V or not!
s_wilwerding 10-26-2012 05:30 AM
If you pull out the console piece in front of the shifter (where the GT3 console would go), it's usually just sitting right inside there.
Meirschwartz 10-26-2012 09:07 AM
wonder if one can get the other side of this connector ?
2003S 10-27-2012 04:54 AM
It is switched 12v. I've tapped my radar detector into it.
pbkirby 10-28-2012 07:07 PM
which wire is the power, which is the ground ?
