Any idea what this connector is for ???
Found it in the shifter console. the following numbers where listed 1-929 529, AMP 1-828 8191, BMW 1-378 134.
P. Kirby 2004 Boxster S 550 Anniversary Edition 2011 Acura MDX 2012 Mini Countryman S |
Factory cell phone...............
Accrochez-vous bien de vos rêves..........." |
The nice thing is that, if you want to integrate your garage door opener or another accessory, you can pull 12 V constant and switched power off of that plug. I added a garage door opener button to my center console using that for switched power.
Steve Wilwerding 1998 3.4L Zenith Blue Boxster 2009 Meteor Gray Cayenne |
Any idea where I can find a wiring diagram for this connector
Looking to find the power and ground, may use for my next sat radio install.
Where was it? Did you have to pull the entire console to get at it? Be nice to know if it's switched 12V or not!
Tom Coradeschi 03 Boxster |
If you pull out the console piece in front of the shifter (where the GT3 console would go), it's usually just sitting right inside there.
2001 Boxter S
wonder if one can get the other side of this connector ?
which wire is the power, which is the ground ?
