trying to diagnose a oil burning issue
I thought was the AOS, so I replaced it.
Possible bad new AOS? ![]() The car smokes on start up and clears after running about 5 mins. under hard accel as soon as it hit 5800 RPM it will belch out a thick cloud of smoke that will cause people behind me to pull over. ![]() Under a couple of the test the computer will throw a code for bank one O2 making me think it is a issue with oil scavenging out of one of the heads. Help! Last edited by healthservices; 08-20-2012 at 10:59 AM.. |
I think later today I will bypass the AOS to see if it is the issue.
Before by-passing the AoS, check and make sure you oil is not overfilled, and consider doing a leak down test on the engine.
Accrochez-vous bien de vos r๊ves..........." |
What year & mileage are we working with ?
Assuming & hoping AOS was the problem, you still have plenty of oil in the intake that gets sucked into the combustion chamber randomly. Check passenger side sparkplugs for fouling starting with #2 in the middle. |
Maybe I can find some type of intake cleaner.
Seafoam? Last edited by healthservices; 08-20-2012 at 11:01 AM.. |
Could too high oil viscosity cause the smoke at hard-driving times?
Author of "101 Projects"
Right - I would give it at least 100 miles or so to clean out all of the excess oil. You can also remove your intake and clean it yourself, but that's a pain...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series 101 Projects for Your Porsche 911 How to Rebuild & Modify Porsche 911 Engines 101 Projects for Your Porsche Boxster & Cayman 101 Projects for Your Porsche 996 / 997 SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Well removed the center joint on the intake to clean and inspect. Yep ton of oil...
Let me see if I can download some pics today. Definitely should clean intake as part of replacing the AOS valve to save a headache |
This is the only one that scares me...
Hope it is only reversion causing this... ![]()
put it back together later today to see what happens...
fingers crossed |
So now we see how Porsche dealers charge $800- $900 to repair failed AOS.
114k miles on 1997
Sorry this one was for someone, I do some side work from time to time. If all goes well I'll do a rear main on this car as well. |
Well it seemed better until I open her up. maybe oil in the air cleaner side of the throttle body?
I'm up loading a video to youtube it will be a while. |
This is after I cleaned it, it is actually better if you can believe that!
I feel like 007 in his car after hitting the smoke screen button. turn volume down, a lot of wind noise https://www.youtube.com/watch?v=M0TSAyRs8AI Last edited by healthservices; 08-22-2012 at 09:57 PM.. |
It is possible the new AOS is also bad, It's not unheard of
Crazy Austrian http://www.ws-ab.com |
a little bit of oil can create a lot of smoke, could it be possible that there is some residual oil in there that is getting sucked in?
That is a lot of smoke. It's possible, but not likely that the new AOS was bad from the factory. More likely may be that the PVC valves in the crankcase are broken / stuck, which would cause a tremendous amount of vacuum and would cause the new (and old) AOS to fail. How is the crankcase vacuum test (remove oil cap with car running)?
-Wayne
