Cam cover bolts...oil weep
All,
I have a bit of oil seeping from the lower 2 cam cover bolts. Nothing is dripping just a weep. I want to remove the bolts and put some Loctite blue then re-tighten to proper torq. Any issue with doing this? I am going to do this when doing my oil change. Thanks Paul
Regards ![]() Paul |
Rather than use Loctite thread locker, put a small amount of Loctite 5900 on the treads and under the bolt head, then torque to spec. Should cure your weepage.
Accrochez-vous bien de vos rêves..........." |
Thanks JFP! You da man!
