-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Linkage problem? (http://forums.pelicanparts.com/boxster-cayman-forum/723157-linkage-problem.html)
crashmy911 12-10-2012 03:27 PM
Linkage problem?
Car is 2003 boxster s with 54,000 miles. When I shift into second some times it goes in and sometimes it doesn't. Usually when I down shift it goes in 9 out of ten times. When it doesn't go in it seems like it doesn't engage. You hear some noise from transmission but no grinding gears. If you try and pull gear lever into second again with out putting clutch in it will grind. If you put clutch in and pull back to neutral then pull back into second it will engage sometimes.
crashmy911 12-10-2012 04:38 PM
When it is engaged it will not pop out.
Meirschwartz 12-10-2012 07:10 PM
remove the center console, and inspect the linkage going to the shifter.
do the same thing on transmission side.
King claw 12-14-2012 08:58 PM
Just curious, what specifically are you looking for? What would be a problem?
Meirschwartz 12-15-2012 10:30 AM
you need to look at the linkage here:
http://forums.pelicanparts.com/uploa...1355596156.jpg
make sure that the rubber bushing inside it, is not damaged.
http://forums.pelicanparts.com/uploa...1355596224.jpg
King claw 12-15-2012 06:50 PM
Thank you.
