Porsche Crest 98 Boxster - Non Firing Engine
I'm looking at a clean 98 Boxster with 64K miles. The owner states that the engine turns over fine, but will not start. Any Boxster owners experience this problem?
Would an IMS failure cause this?
Thanks in advance!
Old 12-16-2012, 10:22 AM
Cajundaddy's Avatar
Out of gas? Failed ign switch?
2009 Cayman PDK With a few tweaks
2021 Cayman GTS 4.0L
2021 Macan (dog hauler)
Old 12-16-2012, 11:39 AM
JFP in PA's Avatar
When the crank position sensor goes bad, the DME does not see the engine turning over and shuts off the fuel. Check your crank sensor.
Accrochez-vous bien de vos rêves..........."
Old 12-16-2012, 11:45 AM
If the IMS has blown up, will the engine even turn over? Or will it just crank with no resistance?
Old 12-16-2012, 05:25 PM
Cajundaddy's Avatar
Sometimes the engine will still crank, sometimes not. It depends on if the timing chains have slipped timing yet. A bunch of ferrous metal frag in the oil filter is a good clue.
Old 12-17-2012, 06:43 AM
Thanks for the feedback. I'll start with the filter.
Old 12-17-2012, 07:43 AM
