Pelican no longer sells the 5 pin connector and cover 999-650-056-40 and 999-650-057-40. What are my alternative options to use as part of the OBC install?
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster On Board Computer (OBC) Upgrade / Boxster Turn Signal Switch Replacement - 986 Boxster (1997-04) - |
Try 999-650-513-40-OEM instead...
- Wayne |
Great. Thanks wayne. It is on my project list to do next when i've completed all service items of my new boxster and got rid of the p1128/1130 codes with a very lean (negative) rkat fuel trim. Hoping swapping out the maf will solve it.
Pleased with my OBC activation
You will like the results of your 4 stalk upgrade. I purchased the Pelican parts kit described in the 101 projects book. I completed the upgrade January 2013 and it works perfectly and I was able to activate the OBC with the Durametric tool.
| All times are GMT -8. The time now is 03:14 PM. |
