Thumbs up Just bought 2000 boxster s
Hi,
Just bought this baby for the summer with 78,000miles.
the paint was so nasty and I tought I will have to paint the car. BUT after 5 hours of work and 2 layers of polish and 2 layers of wax the paint looks like new
Have some issues to fix:
1. there is a noise from the rear right when passing on bumps. any ideas?
2. when moving from 2 to 3 gear i feal a little bang (tiptronic), could it be the engine mount?
3. I see an oil leak. I need to clean the engine to see where it comes from. any known places for boxsters?
4. speakers - it seems that one of the owners before did a stupid job and chancheled the front speakers. put only tweeters. now I need to set a new 4" speakers but don't have the old speakers to use them as a base. any idea how to do it? or I must buy used speakers from ebay?
I will post pictures later.
Thanks guys
Yaron
1982 Black 911sc coupe
2000 Boxster S
2007 Harley Davidson Night Train (very customized)
1971 conv' beetle, 2332cc (sold )
Old 02-03-2013, 07:26 PM
post without pics is worthless :)
and for the two babies:
2000 Boxster S
Old 02-03-2013, 09:55 PM
One more thing.
When I'm starting the car COLD it start after 3 second starter spinning. not fast but ok. when the car is HOT (and sitting above 5-10 minutes) it starts after some starter spinning and on the second try with a little press on the gas pedal.
What can it be?
Thanks,
Yaron
2000 Boxster S
Old 02-03-2013, 10:12 PM
Alphaboy1's Avatar
Oil leak would depend on where it is originating. Worst case "RMS" Rear Main Seal. Not so bad "Spark Plug Tubes"
Regards
Paul
Old 02-04-2013, 11:29 AM
BR_ BR_ is offline
wow, that looks pretty good. Do you have any "before" pics to see how much you've improved the paint???
Old 02-04-2013, 04:44 PM
txhokie4life's Avatar
Tranny mounts can go making a clunking sound.
They can also leak their fluid which looks like oil.
Clean up the engine and look for the oil -- also
put a piece of card board or something down where
you can see the drops.
Depending on mileage -- consider replacing the water pump -- or at least have one handy,
they can last 30k miles or forever.
The other clunking source can be the engine mount. They go bad as well.
Had one go on my Boxster S 6sp -- but didn't realize it -- and once I did
figure it out -- it had also worn my tranny mounts.
BTW, I like the 82 SC, but was amazed at how small/tight they are inside -- esp
considering my Boxster was a DD for 4 year!
Mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo
2001 996 GT2
1999 Spec Boxster, 1996 993 Cabriolet
1992 964 Cabirolet, 1975 911 RSR Replica Race Car
Old 02-04-2013, 05:05 PM
NYC
After you check you ball joint and all components and if it checks out,check the bushing at the end of the strut bar. That can be your noise. It seems to always sound like it is coming from your strut assembly. You might have to buy a set of speaker housings from Ebay. Most of the time people have to modify the plastic housing to install after market speakers. There are some good suggestions on the oil leaks from the other members but also check the bottom of the AOS where it is attached to the engine. Often the o ring seal might leak there. As far as the starting condition, It could be anything. Often a crank sensor will start to display those symptoms you speak of. However I have come across many fuel delivery problem on these cars.I have even come across a very dirty air filter almost have displayed the same symptoms.Remember always remove the filter and turn it upside down to check because the top of the filter will look clean. JW
Old 02-04-2013, 05:26 PM
Thanks guys.
It seems I have a lot of work ahead
2000 Boxster S
Old 02-04-2013, 10:48 PM
