RalphyT (guest)
Guest
Posts: n/a
When I gently depress the brake pedal the brake lights don't activate. As pressure is applied the brake lights come and will stay on as long as the amount of pressure doesn't change. As the pressure on the pedal increases the lights go back out. Sound like this switch??
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Brake Pedal Switch Replacement / Clutch Pedal Switch Replacement - 986 / 987
Old 02-10-2013, 05:06 AM
ghtaboma's Avatar
brake lights
I had the same problem with my 2001 "S".. Be sure to get the stock factory switch, and not an online one. They don't work! Those suckers are hard to get at!
Old 02-10-2013, 03:43 PM
