-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Question on Boxster Common Engine Failures (http://forums.pelicanparts.com/boxster-cayman-forum/733452-question-boxster-common-engine-failures.html)
howie (guest) 02-10-2013 12:25 PM
currently my wife has a 2001 boxster s as the weather got colder haven't been driving as much. Now shifting between 1 2 3 the engine is over revving before engaging and the engine with a high pitch whine.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Common Boxster Engine Problems and Failures - 986 / 987
Wayne 962 02-10-2013 12:25 PM
Unfortunately, you have an provided me enough information to diagnose this problem. It could be a clutch issue, where the clutch is slipping, if you have a manual transmission. It could be an issue with your automatic transmission, and the fluid inside, if it's slipping before engaging. Off the top of my head, it doesn't seem like it would be an engine issue, the more of a transmission issue. I'm going to copy this question to the forum, and if you can add some more additional information there, perhaps we can help further.
- Wayne
