Andy (guest)
Guest
Posts: n/a
Any idea where replacement factory spring hose clips can be found to replace the originals?. I have a special tool used for the spring clips which makes using these very easy.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Coolant Replacement / Boxster Coolant Flush - 986 / 987
Old 02-10-2013, 08:24 PM
Author of "101 Projects"
Wayne 962's Avatar
If you're looking for the factory radiator hose clips, then we can special order those for you. Give one of our sales reps a call at 888 – 280 – 7799 and they can look those up for you. The factory clips are interesting. I originally thought they were a cheap solution to the older style clamps, but I was recently educated on the fact that because they are spring-loaded they apply a uniform pressure across the circumference of the hose no matter what temperature the hose gets. In other words they apply uniform pressure under almost all varying conditions. I still like to use the older style clamps, but these also work just as well
- Wayne
