Porsche Boxster: Replace Clutch Interlock Switch
I have ordered this part for my Porsche Boxster (986 2004) and need to get instructions as to how to replace it. I think it looks simple but was curious if anyone had instructions on how to replace it. Thanks
interlock switch
These are hard to get at. Switch is similar to the brake switch. See 101 Projects for the Boxster.
I replaced the interlock for the cruise control this weekend. Took about 3 mins to do, but it was the easy one to get to. Basically push the switch housing against the metal bracket and twist a half turn. It will then slide out the back of the bracket. Unplug the switch from the wiring and reverse for assembly. It is the is interlock for starting it is pretty far in there and may take some contorting to get to. 101 book suggests using pliars to grip for removal if necessary but warns that it most likely will break the switch..
| All times are GMT -8. The time now is 08:52 AM. |
