jporter1966 (guest)
Guest
Posts: n/a
I have a supercharger on my boxster and am having some running issues. I am wondering how can I tell if the extra injector driver is working? I am getting either too much fuel or not enough under low rpm acceleration in a higher gear and under very hard acceleration. Can you assist and if it is the driver can it replace? Where would I find one?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Superchargers / Boxster Turbo Chargers - 986 / 987
Old 04-23-2013, 01:12 PM
The supplier of your supercharger system sould be able to give you a diagnostic procedure. You could also check for signal with a lab scope. Another possibility is monitoring your Oxygen sensor voltage to check fuel mixture. If your mixture is going lean you can quickly damage your engine. We do sell a fuel mixtue monitoring device. it is listed on our web site.
- Denny
