DLB (guest)
Guest
Posts: n/a
My car is making a humming sound but only once in awhile. I believe it has something to do with the fuel system because when I engage the accelerator it goes away. Not sure what it may be. Car 2002 Boxster 2.7
Another question: I replaced the four O2 sensors are there any adjustments that are required?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Engine Sensor Replacement - 986 / 987
Old 04-23-2013, 04:05 PM
There are no adustments needed for the oxygen sensors after replacement. If you had a check engine light on it will need to be reset.
- Denny
