-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Question on Boxster Engine Sensors (http://forums.pelicanparts.com/boxster-cayman-forum/746234-question-boxster-engine-sensors.html)
Ricey (guest) 04-23-2013 04:03 PM
Figure 4 "The purple arrow shows the crank angle sensor or flywheel sensor"
For the crank position sensor, can you advise what type of bolt is holding the sensor in? Need to know the length also
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Engine Sensor Replacement - 986 / 987
Denny at Pelican Parts 04-23-2013 04:03 PM
My reference shows a 6MM X 16 MM. It should be a torx bolt. I recommend getting a set of torx if you are working on your Boxster. Various sizes are used.
- Denny
