turboflyer's Avatar
01 Boxster S no right side running lights ?
I am having a heck of a time. All fuses look good, wiring looks good, And bulbs good. I do have turn signals and brake light. Left tail lights all working. There is no power for running lights going to the pins on the right tail light plug. So just not sure what to check next. Thought maybe the light switch but that is a pricey little piece. Especially if there is some hidden fuse or connector. No crash damage and I an the original owner. Sitting at 90K. Appreciate the help.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci
2007 Ducati 999S Team USA , 2005 BMW BCR R1100S
2001 Boxster S w/tip
Old 06-27-2013, 06:17 PM
turboflyer's Avatar
Found it. Faulty front running/parking light socket. Apparently the side marker light and tail light share the same circuit. Plenty of time chasing this but there you have it. Hope this helps some one else some time.
Old 07-05-2013, 11:11 PM
