-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   I am fitting a 2003 986S engine into a 2001 986 2.7, both with manual gearboxes. (http://forums.pelicanparts.com/boxster-cayman-forum/755891-i-am-fitting-2003-986s-engine-into-2001-986-2-7-both-manual-gearboxes.html)
agd931 (guest) 06-14-2013 03:39 AM
I am fitting a 2003 986S engine into a 2001 986 2.7, both with manual gearboxes. Can you please clarify your comment that the DME connector printouts have to be slightly modified. Whichnpinsmhave to be modified & why, and also which sensors do these pin outs relate to. I can see that there is a difference between the 7.2 & 7.8 DME's with regard to DME connectors 1 & 4. I already have a Motronic 7.8 DME, keys/immobiliser and engine wiring harness. . I also have access to the crash damaged 2003 986S that has donated its engine, so I can remove any additional parts that may be required.
I appreciate your assistance and look forward to your response. Thanks Arthur.
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 06-14-2013 03:39 AM
How much would cost to repair a Ims destroyed 2000 2.7 boxster engine?
- Nick
