-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Question on Boxster Common Engine Failures (http://forums.pelicanparts.com/boxster-cayman-forum/756037-question-boxster-common-engine-failures.html)
gunna!! (guest) 06-14-2013 04:08 PM
when porsche boxster has a blow from the exhaust what could it be? but the blow gos after a bit dont under stand!! so is it just the exhaust????
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 06-14-2013 04:08 PM
I assume you mean backfire. This could be cause by the cylinder not firing and the exhaust igniting the mixture as it leaves. You could have a burnt exhaust valve. Check compression in each cylinder
- Nick
