Tsunamiboy's Avatar
Can the clutch be adjusted? 2006
The clutch pedal on my 2006 standard Boxster has quite a bit of travel with the engagement closer to the top of the pedal, is that normal? It shifts just fine and no slipping. Is there an adjustment for the clutch pedal or is it self adjusting???
Tsunamiboy
1979 911 SC (3.2L)
1997 Boxster 986
Old 07-11-2013, 09:22 AM
Good question...
I would like to know too. Mine engages toward the top as well... I second the question.
Old 07-11-2013, 10:07 AM
JFP in PA's Avatar
There is no mechanical adjustment, the system is hydraulically operated.
Accrochez-vous bien de vos rêves..........."
Old 07-11-2013, 10:46 AM
I would think that engaging at the top is a good sign that there is still plenty of material left on your clutch. You do want you clutch to engage close to the floor. Plus, if you can figure it's exact point of engagement / disengagement then you learn to shift faster with less travel.
Old 07-13-2013, 05:12 AM
I had heard something like that in the past so I guess good news for us. Agree on the shifting too..
Old 07-15-2013, 07:17 AM
Just the opposite in my opinion (from other vehicles anyway). If your clutch is engaging/disengaging at the very beginning of pedal travel, I would think the clutch is more worn.
Roger
'08 Boxster S, and over the years a few others. A daily driver 911SC, and a 356B... you guessed it - a Super 90!
Old 07-15-2013, 11:39 AM
