-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Also, I need to install an extra oil temperature sender. Are there possibilities ? (http://forums.pelicanparts.com/boxster-cayman-forum/761374-also-i-need-install-extra-oil-temperature-sender-there-possibilities.html)
Pete (guest) 07-16-2013 02:57 PM
Hi, congrats with your explanations... we here in Europe also use them...
Have a question though... want to install VDO instruments DIN mid console : oil temperature, oil pressure and voltage. I need the ones with the white dials. Do you know which ones go best with the white cluster of my boxster, especially when illuminated. Also, I need to install an extra oil temperature sender. Are there possibilities ?
Best regards
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 07-16-2013 02:57 PM
Give our parts specialists a call at 1-888-280-7799 and they can help figure out which part or repair kit you need.
- Nick
Hatzenbach 07-16-2013 07:04 PM
Here is a thread which explains where/how to install the oil temp sensor including part numbers:
Oil temp sensor - 986 Forum - for Porsche Boxster Owners and Others
