-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Currently I'm having an issue where the car will run fine for about 20 min. then die out on me. (http://forums.pelicanparts.com/boxster-cayman-forum/761382-currently-im-having-issue-where-car-will-run-fine-about-20-min-then-die-out-me.html)
realtalk214 (guest) 07-16-2013 03:19 PM
I have a 99 boxster with 125k miles on it. Currently I'm having an issue where the car will run fine for about 20 min. then die out on me. If I wait about an hour the car will start right back up and drive no problem for about anothe r20 minutes or so. No CEL or anything, I've already replaced the fuel pump but same results. What else should I look at?
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 07-16-2013 03:19 PM
Sounds to me like you have a bad crank sensor failing when it gets hot.
- Nick
stuttgart46 07-17-2013 05:06 AM
I'm going through the same thing. I have already replaced the crank position sensor. I am going to have Einar run a scan and try to figure out what's going on. It's very frustrating.
stuttgart46 07-26-2013 04:58 AM
We ran the scan and it showed the MAF Sensor was bad. I had cleaned it since all of this started but not replaced it. Apparently cleaning it was not enough. I replaced it yesterday and all is good. The car seems to run better as well.
