-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Question on Boxster Common Engine Failures (http://forums.pelicanparts.com/boxster-cayman-forum/761524-question-boxster-common-engine-failures.html)
rob (guest) 07-17-2013 06:10 AM
Hi I have a 2001 boxster s shes stood for some times, an reasantly the brakes have gone rock hard? It stops but you've really got to push? The servo is acting ok , pump the peadel an then start peadle sinks slightly so in my mind that's how it should be! Any thorts would be fantastic!
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 07-17-2013 06:10 AM
If the pedal is rock hard, the brake booster could be faulty, or you could have insufficient vacuum to the booster.
- Nick
