 Ignition Switch Questions After reading through Project 86 & several threads on topic, I still have a couple questions. (I posted them here but figured putting it in the main forum might get more responses) Here's my situation: '01 S & I don't believe I have the upgraded mechanism. Yesterday, my key was tough to get into the slot. When in, it turned & the car started but the spring didn't pull it back from 'Start' to 'Run' like it had before. Also, when shut off, I had to hold it all the way to the detent that allows the key to be removed (& the electronics to shut off). It's like the springs let loose & the detents are off. Are the springs & detent mechanisms in the replaceable portion of the old mechanism (Part # 4A0-905-849-B-M56 on Pelican)? Or are they in the main mechanism meaning that I need to replace the whole thing? Either way, it appears to me that I can reuse the existing tumbler & keys...correct? Thanks! |
 hi there, this is what happened to my 99. do all your electronics work? I was able to just replace the switch and it took about an hour. Roy |
 I've had the same issue with my switch but it also didn't shut off my car when I took the key out, you can still reuse the tumbler and keys. I just got my switch at Autozone for around $25( with employee discount) it was locally here. installed it and it works like a charm! Plus lifetime warranty, can't beat that! But if you want to go OEM I'd go with what they have here. |
 I think I'll order one here as well & keep it in the frunk for when this one dies! The little screwdriver from my Craftsmen set worked great to undo the set screws & my 'head-light' (forehead-mounted LED flashlight) made it possible for me to see! |
| All times are GMT -8. The time now is 01:24 AM. |
