2000 Boxster/ rough idle and these codes
Hi everyone, I'm experiencing a rough idle on my boxster. I hooked up the Durametric and I have the following codes:
P code 174 P code 62 P code 65 cyl 3 misfire P code 63 cyl 1 misfire P code 64 cyl 2 misfire. I had a misfire on a single cylinder a year or more ago and it was a hairline crack in a coil-pack. Any ideas what would cause 3 cyl. to miss all at once? I only replaced the 2 worse coil-packs last time. But its been running great until recently. I replaced the CPS which cured my hot-starting issues. The roughness seems to smooth out with increased rpm's although Its probably just less noticeable. Any input greatly appreciated. Thanks, Garry |
Possible causes: - Short to ground - Actuator faulty - Open circuit in triggering wire - Open circuit in B+ supply - Actuator faulty
Accrochez-vous bien de vos rêves..........." |
Will a durametric short test help to identify some of these problems?
Or are there any other tests I can do to help diagnose with durametric? Is there a toggle test for the acutator? Thanks, Garry |
