-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Rear boot lid fix (http://forums.pelicanparts.com/boxster-cayman-forum/781574-rear-boot-lid-fix.html)
derfo 11-14-2013 09:27 AM
Rear boot lid fix
Here are a few photos and text of my boot lid fix. It may be helpful to some of you if you get the same problem.
This is the manual cable I left it in this position for now.
http://forums.pelicanparts.com/uploa...1384449166.jpg
This is the problem, can you see the frayed cable on the right.
http://forums.pelicanparts.com/uploa...1384449285.jpg
This is what I used to fix it. An electrical cable connector and some braided wire cable.
http://forums.pelicanparts.com/uploa...1384449413.jpg
I took one of the barrels out of the connector, then threaded the frayed cable through it. Next I threaded two ends of the new cable through it from the other end, forming a loop and clamped it all together with the screws. This loop goes over the post. There is a clip on the post, take it off first, but don't forget to put it back.
http://forums.pelicanparts.com/uploa...1384449896.jpg
I hope this is helpful to you. If you have any questions just ask.
jwgn777 11-14-2013 02:06 PM
Nice quick fix.
