02 Boxster idle issues
My wife's '02 Boxster is experiencing some issues with idle. A couple of weeks ago she said it was having troubles backing out of the garage after a cold night. So I started coming out about 15 minutes before her leaving for work and giving it a good warm up. But I didn't notice any problems after starting up. Then last Friday it threw a code with the check engine light. The Durametric revealed this...
http://forums.pelicanparts.com/uploa...1387119497.jpg So I clear that code and instantly the idle goes to crap :eek: So I looked at the real time readings and nothing is really jumping out at me (low voltage on O2 sensors, MAF, etc) The only oddity is the two TPS show different readings - TPS 1 is low at idle .5 V and TPS 2 is high 4.5 V (both approx.) So I take the car for a drive to watch those readings and at 1/2 to 2/3 throttle those move toward each other which I believe is normal. And, when I get back to the house after a few minutes, the idle is mostly smoothed out (fluctuating about 250 RPM). So I called a trusted mechanic and after describing everything he's thinking vacuum leak. And because it's both banks, he thinks pre-throttle body. Cold weather here so I take great care opening up the engine compartment by warming up the car and garage (don't want to have to by a new top :mad:). Nothing amiss in there. All readily accessible hoses tight and secure. I sprayed some ether around some of the junctions trying to affect idle but no changes. So do these symptoms sound familiar to anyone? Are there any vacuum hoses prone to leaking in cold weather? My mechanic buddy says they've been seeing a lot of cars with leaking o-rings in cold weather. |
Here are the areas to look at:
-- Incorrect signal from MAF sensor – Intake air system leaking – Fuel pressure too low – Volume supply of fuel pump too low – Fuel injectors fouled – Exhaust system leaking Do in order: 1) Check MAF 2) Check for exhaust leaks 3) Check for intake leaks 4) Check fuel pressure/volume Since you have the Durametric check the actual values of the MAF sensor: Ignition on, engine off: 0.9 to 1.1 volts Engine on (at idle): approximately 1.4 volts. Regards, paul... |
PM sent
Regards, paul... |
My 02 started generating a CEL along with some error codes -- I can't recall them now -- that had me thinking MAF. I was so convinced after some weeks that I replaced the MAF. Turned out the problem was a leaking oil filler tube cap.
Another time on a cross country drive the CEL would come on and the error codes -- as above I can't recall them now -- had me thinking MAF. I decided to press on and the 3rd day after reaching my destination upon cold engine start the exhaust billowed oil smoke. Not MAF. AOS. |
| All times are GMT -8. The time now is 09:30 PM. |
