Getting a slight clunk on take off??????
Getting a slight clunk on take off. I replaced the inner CV joints since the boots were both separated. This did not get rid of the clunk. Any thing else I should look at?
01 boxster S tip
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci 2007 Ducati 999S Team USA , 2005 BMW BCR R1100S 2001 Boxster S w/tip |
Motor mounts, and in particular, the front one.
Accrochez-vous bien de vos rêves..........." |
Thanks , is there a proven layman way to check?
one of gods prototypes
Yep. .... put it in first or second gear.... jump on the throttle. ....if you hear a thunk coming from behind the center console its the Front Mount.
Pretty common.... |
Great will check it out. Its the month for that for sure.
Have the new motor mount. The super great folks at Function first are sending the mount upgrade inserts.
All done. Not that big a deal. Not real happy with the extra vibration and noise but it is not horrible either. Maybe it will break in and loosen up a little. Yep broke both hose clamp mounts, oh well.
