-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   2002 3.2 Timing engine (http://forums.pelicanparts.com/boxster-cayman-forum/795175-2002-3-2-timing-engine.html)
edwardneff94 02-04-2014 05:54 PM
I have a 3.2 that bent some valves, I have rebuilt the heads and have them ready to go back on, my question is do I have to have the 9599 tools to set the timing? If I understand it they are just needed due to the fact that there is no oil pressure to pressure up the chain tensioners? With that in mind could I use my pre oiler that I have to build oil pressure up in the engine and pressurize the tensioners? If I do have to have the tool does anyone know of someone that I could rent it from for a few days? Thank you guys for all your help.
tordenskjold 02-05-2014 09:20 AM
I just used the tensioners themselves and it all worked well. Frankly I do not know why the tool needs to be used. Maybe someone else knows.
BYprodriver 02-05-2014 09:36 AM
You don't need the Porsche tool. Prior to installing the lifters/followers & 3 tensioners clean & test them. Submerge the parts in fresh, clean,hot oil & pump the plungers until all old dirty oil comes out. Install tensioners until they just contact the sealing rings but don't finish torque incase you need to disassemble for some reason. Set cam timing. Once everything is set & you are ready to proceed, torque tensioners & Reset cam timing.
http://forums.pelicanparts.com/uploa...1391621774.jpg
edwardneff94 02-05-2014 11:09 AM
Thank you for the advice, I will use this method as soon as our weather get a bit warmer here, 16 degrees today.
txhokie4life 02-05-2014 03:26 PM
Bacon grease is the best!
