Boxster 3.2S ,Cayman 3.4 conversion
Just a noob with a pitiful request for guidance to info.
I just bought a 2001 Boxster S 6 speed manual trans.Previous owner spent lot$ with Pelican for upgrades/parts. The engine developed awful rod knock within a few days of purchase!Babbitt bearing(?) swarf in the oil pan and spin-on filter. A rebuild will cost more than I paid for the car .Very depressed. A sympathetic buddy found me a 2006 Cayman 3.4 Tiptronic engine with only 8000 miles for only $3000 with all ancillaries but no DME-Woop-ie !! Got Bentley, Wayne's book ,read all I can find on this engine conversion .It seems all I need according to Wayne's helpful write-up is: 1. 7.8 DME & modify the pin-out of the connector on the Cayman motor 2. ABS controller & connector from a 3.4 Cayman 3. My flywheel +clutch +6 speed trans will fit O.K.?? I already have the trans. out of my 'dead' car and was about to drop the engine & start tearing in to the knocking engine when the Cayman alternative was offered.Yes, I do all my own wrenching. Please tell me what I should do -rebuild or do the swap? I already have a 'delicate' situation with the wife because of the money pit I have stupidly bought, so I don't want to screw things up further by installing an engine that won't work or produce a car w/o ABS ...I don't need a detailed explanation(although that would be great!). Just point me in the right direction. As I said ,I've got Wayne's piece just about memorized because I have read it so many times! Either way it will make a great write-up for this Forum.http://forums.pelicanparts.com/uploa...1399693514.jpg http://forums.pelicanparts.com/uploa...1399693625.jpg |
Scnell,
Sorry to hear of your troubles. Suggest you also post your question over at 986forum.com (also owned by Pelican). There are a lot of very experienced mechanics on that forum, and it's more heavily trafficked than this site is. kjc |
kjc,
Thank you for the suggestion.I'll do that. |
Why not keep the knowledge here?
| All times are GMT -8. The time now is 11:48 PM. |
