Axle bolts sheared. Is this common?
I was driving home the other day, and heard a "pop". then there was a weird vibration. At first, I thought I had blown a tire, and pulled over to check it out. To my surprise, the tires were fine. So I got back in, and went to pull away. Nothing! The engine revved, but the car just sat there.
I had just had the transmission fluid change when I had the IMS bearing replaced. So the first thing I thought was possibly a broken line. but no fluid leaking. I had it towed back to the shop that had done the work. The verdict? Sheared axle bolts. The tech told me he had done "quite a few" in the past few months. I'm a bit confused. I haven't really heard of this being a common failure. Am I just missing something? Are the bolts that attach the axles to the transaxle really aluminum????
1968 912 (killed by a stripper in Smithtown) 1986 944 (sold to make room for the 98) 1998 boxster 2000 Boxster (aka money pit) 2013 Honda VT1300 Interstate |
Platinum Member
M8 bolts, driveshaft to transmission flange should be torqued to 29 ft-lb and be re-torqued after a few hundred miles. |
Accrochez-vous bien de vos rêves..........." |
Kind of what I was thinking. He lost me when he said the bolts were aluminum. I need to learn to do more research before picking a shop to do work on my car.
Axel bolts
How many miles since your IMS bearing replacement?
I have a couple hundred miles on my 2004 S since replacing the IMS bearing, clutch and flywheel. The S does use larger bolts. They are not a replace each time used Item like the fly wheel bolts. As I recall they were torqued to 60 ft lbs. Most bolts in the Boxster have a specified torque and over torquing can be just as bad as under torquing. The cylinder nuts on aircraft engines are a good example. Years ago when I lived in my hangar at Flabob airport (Riverside, California) we had a guy that would fly in with his homebuilt Great Lakes Bi-plane. It had a inverted in-line engine out of a Spanish built Jungman. I asked him what the torque was on the cylinder nuts. He said that he just tightened them up with a wrench. On his way home after one of his trips he had a cylinder depart and he ended up in the top of a tree in Pasadena. |
I had the IMS done maybe 450 miles ago. picked it up 2 weeks ago. and drove it to Butler PA and back. (I'm in Alexandria VA) since then just a couple of trips to work and back. Thank god all I ended up with was a tow back to the shop. Beats the hell out of anything having to do with Pasadena! Oh and did I also mention, I had the car back 2 days and it threw a P1128 code? If it ain't one thing it's another!
