-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   need help, please (http://forums.pelicanparts.com/boxster-cayman-forum/821619-need-help-please.html)
irish03 07-20-2014 03:08 PM
need help, please
My son has a 98 Boxster. The module under the drivers seat seems to have become disconnected. (this happened once before) The problem is the power seat will not work due to the module. I need to move the seat about 1 to 2 inches to remove the rear bolts of the seat. There's no room to get to the seat motor(s). Is there anybody out there that can help me with this problem?
Bill:confused:
JFP in PA 07-20-2014 03:17 PM
Bill:confused:
http://www.caseyholzer.com/blah/car/...r_harness1.jpg
http://forums.pelicanparts.com/uploa...1271993547.jpg
irish03 07-21-2014 06:42 AM
need help
I understand where everything is at. Thank you for the pictures. But I need to remove the bolts from the rear of the seat. But the seat rails are in the way. I need to find a way to get the bolts out to fix the module. The power to the seat cut when the module came loose. I don't want to pay $250.00 to a dealer again.
irish03 07-23-2014 01:02 PM
I believe the pictures are from a 911 or something else. Does not show where the connection is located. I only have to move the seat 1 1/2 inches. I need to do this to remove the rear seat bolts. The picture shows me the connector not where it is located. ANY help out there. Thanks in advance.
Bill:confused:
