-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Mph digital display problem (http://forums.pelicanparts.com/boxster-cayman-forum/824225-mph-digital-display-problem.html)
dmcummins 08-06-2014 05:14 PM
The best I can explain is it looks like a big snowflake is covering the left number on the digital mph display. Any ideas on what is wrong? How do I fix?
dmcummins 08-06-2014 05:26 PM
A pic.
http://forums.pelicanparts.com/uploa...1407371170.jpg
steveng1993 08-06-2014 06:19 PM
Looks like the LCD is cracked right there.
Mike Thomas 08-09-2014 11:46 AM
That's a real bummer. I hope it's easy to fix, because the analog speedo on these things is useless. Best of luck!
dmcummins 08-10-2014 08:32 AM
I looked on ebay for a used gauge cluster. Only problem is it looks like I need one from a 2000 S with tip. The ones I saw for sale were good for 2001-4 or so.
If its a one year only cluster I will probably just have to live with it. I don't think I could find one. I will probably call one of the used parts places and see what they have. No way I'm paying for a new one from Porsche, just too expensive.
dmcummins 08-10-2014 08:33 AM
It happened when I was pulling it behind a Uhaul on a auto transport. I hauled it from St. Louis to Southwest Florida. I may have hit a bump along the way.
thom4782 08-10-2014 10:18 AM
If nobody suggests a DIY way to repair, you might give Palo Alto Speedometer a call and see what they have to say. They are Palo Alto, CA.
stealthn 08-16-2014 03:47 PM
What is this "miles per hour" you speak of :)
KevinH1990 08-17-2014 11:47 AM
I had the same issue about 2 years ago. At that time I did extensive research and was unable to find anyone who could repair the damaged lcd including Palo Alto speedometer. You can read about my efforts here: Carrera Gauge Swap - 986 Forum - for Porsche Boxster Owners and Others
My work was associated with an effort to swap a Carrera gauge cluster into my Boxster. I was eventually able to re-program the undamaged circuit board from my Boxster so that it could support the Carrera gauges. Send me a PM with your e-mail address if you want the programming instructions. You could easily reprogram the circuit board from a Boxster or Carrera that someone is parting out and make it work in your car. Just make sure you obtain a cluster from the correct year car. You can check Wayne's instructions here: Pelican Technical Article: Boxster 996 Gauge Cluster Upgrade - 986 Boxster (1997-04) - for guidance on which clusters will fit your car.
Good luck.
dmcummins 08-19-2014 03:26 PM
Good luck.
Thanks for the info, I think for now I'm just going to live with it. Since we have just moved here the wife has gone nuts with getting the house in shape.
mikefocke 08-19-2014 04:53 PM
There are places which specialize in used Porsche parts.
List here.
dmcummins 08-20-2014 04:16 AM
List here.
Thanks, my problem is I have a 2000 S with tip. It appears the direct replacement is a one year item and I'm not sure how many 2000 S with tip are even out there. The 996 option helps, but might be more of a hassle.
But I'll give a few of the salvage yards a call, maybe I'll get lucky.
Thanks again for everyone's help.
KevinH1990 08-20-2014 04:35 PM
You will need another circuit board from a tiptronic car, but if you reprogram the board you can re-use your gauge faces and trim rings. (The S gauges have silver trim rings and the analog speedometer goes to a higher level.) According to Wayne's technical article, circuit boards from 1997-2000 tiptronic Boxsters should work in your car.
In addition to the salvage yards Mike listed, the various Porsche web sites usually have ads from forum members for cars that they are parting out. Check here, Renntech, Pedro's Board and the 986forum for a while and you should find something at a good price.
Obviously the flaw on your speedometer is something you can live with, but its right in front of you all the time when you are driving. To me, it would be like talking to someone with a piece of spinach in their teeth.
Good luck.
