-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Code P0133 - replaced O2 sensors but CEL returns (http://forums.pelicanparts.com/boxster-cayman-forum/831887-code-p0133-replaced-o2-sensors-but-cel-returns.html)
ebbjak 09-29-2014 12:55 PM
So I pulled code P0133, nothing else. Based upon what I read, I replaced both pre cat O2 sensors and cleared the codes. About 30 miles later the CEL came back on. Again it was indicating P0133. I checked connections and reset the codes. Again, about 30 miles later the CEL came back on. Thoughts?
JFP in PA 09-29-2014 01:18 PM
Year and model of the car would be helpful.
You may now need to hook the car up to a Porsche specific scan tool like the Durametric system so that you can see the O2 sensor voltages in real time in order to find out what is going on.
ebbjak 09-29-2014 02:43 PM
whoops. sorry. 2001 Boxster S 38,000 miles. I have a new scan tool scheduled to arrive tomorrow that I can use to check further
ebbjak 10-02-2014 07:40 PM
How's this?
http://forums.pelicanparts.com/uploa...1412303990.jpg
bell 10-03-2014 04:58 AM
What is the fuel trim (adaption) reading? Could easily be vacuum leak related
matt demaria 10-03-2014 07:39 AM
According to Poses, P0133 is Signal period for bank 1 is ageing. "With an old senso, the duration of the period is too long..." The period is measured at .2V on the rise ramp to .1V on the falling ramp. The limit is about 1 second for an old sensor.
Your software has indicated an issue with B2S1. Is your software accurate or is Porsche's software off? I have seen issues with Porsche's software misidentifying the engine banks. But there is an issue with B2S1. You also might have a problem with the new sensor you installed. You can unplug the sensor to verify whether it is bank 1 or 2.
IIRC there might have been a TSB for reflashing the DME for an O2 issue for your car.
roofrack 10-03-2014 09:29 AM
Scan tool?
If you don't mind me asking, what kind of scan tool did you get?
yupaleus 10-07-2014 09:28 PM
I had a persistent cel for 7 yrs. off and on. Changing the regurgitation tank vent line/valve seems to have cured it for me...about 200 mi cel free, a record, knock on wood
ebbjak 10-10-2014 07:23 PM
The fuel trim is unremarkable. The Long Term fuel trim is constant at .73 and the short term most common reading is .76 but varies with the highest going to 5.7 and then almost immediately going to -5.7.
http://forums.pelicanparts.com/uploa...1412994142.jpg
ebbjak 10-10-2014 07:57 PM
Pulled from a blue tooth dongle and Torgue Pro app for android phone
It is an OBDII Bluetooth adapter made by BAFX Products, you'll also need Torque Pro app for or something similar for your smartphone to plot the data above.
