Yimex
A couple of steps back please - how do you remove/replace the BULB in the Hazard Warning Light SWITCH. Does it simply pull-out or does the switch need to be disassembleud?
This post was auto-generated based upon a question asked on our tech article page here:
Old 12-02-2014, 09:02 AM
Nick at Pelican Parts's Avatar
If I remember correctly, there is a small socket you remove, once the switch has been removed. Then pull the bulb out.
- Nick
