Wyvern's Avatar
Fan Hack (radiator & engine)
Hi there .
I have searched and seem to be going around in circles .
I want to do both hacks .
Able to manually switch on .
Every post I find either is not Cayman (gen1 specific) or it becomes a why .... get a 3 rd radiator . or very vague info.
I Have even found and signed up for other forums ... but not the specific info I am after.
I need to know where are the rad fan relays.
Where is the engine compartment fan relays
( I thought I had found them but grounding every relay above the fuses did not activate the fans )
Any specific info on my questions . links or other info would be greatly appreciated.
Thank you very much in advance
Brian
Old 02-05-2015, 09:10 PM
Brian: do you have the Bentley manual? I believe that all that you want,regarding this project, will be in there (mostly in the wiring diagrams).
Tom Coradeschi
03 Boxster
Old 02-09-2015, 03:37 AM
