Eugene (guest)
Guest
Posts: n/a
Hi Everybody. I have a MY2000 986 Boxster 'S'. I installed a MY2004 996 3.6l engine into the Boxster 'S'. I also installed the Motronic ME 7.8 ECU. I also installed the 996 Carrera Instrument Cluster which includes the Battery charging rate gauge and an Oil pressure gauge. The car runs like a dream and has plenty power/torque. My only problem is that I cannot get the A/C to work. The A/C relay wire White/Green on the 7.2 Motronic is on Plug II Pin 18. This was moved to Plug D Pin 27 on the 7.8 Motronic. No problem.
There is however a wire White/Red coming from the Boxster's M573 Climatronic Control Unit. This is the A/C Demand wire that goes to Plug IV Pin 6 on the Motronic 7.2
I cannot find the equivalent 'A/C Demand' Plug/Pin on the Motronic 7.8 or on the 996 Carrera's Climatronic Control Unit by the way, it's also a M573 Control Unit. Any help would be most welcome. It's hot in South Africa this time of year! Wayne, your books are fantastic, thank you! Regards, Eugene Dittberner
This post was auto-generated based upon a question asked on our tech article page here:
Old 02-09-2015, 09:49 PM
I seem to remember this issue on a customer car, and I believe the A/C request is sent via CAN between the DME and Climatronic on the 7.8 cars. As I am sure you realized the DME needs to see the request from the Climatronic control unit. White/red is usually a switched B+ signal. Could you verify that the RED/White wire has solid B+ 12v when snowflake active?
- Casey
