Question on IMS Bearing Replacement
Have 2001 Boxster 2.7 94,000 miles with original clutch and dual row IMS bearing with no noise or indicated problems, however, intend to replace it when I do the clutch soon. Would like to use the Pelican Parts update kit(PEL-IMS-1) and the LN installation tool kit (LN-101-08-13) for the job. Have read the Pelican directions in Wayne's 101 Projects book and the LN instructions on their web site and many of these posts, but have read conflicting information if cams need to be locked before removing the IMS bearing when using the Pelican kit on a 5 chain motor.
In the instructions in Wayne's book for the Pelican kit there is no mention of locking the cams on the 5 chain motor with a locking tool - is this necessary or not? If cams should be locked please explain the procedure how is it done since the motor must be rotated to line up the correct position for the set screws, which would leave it off TDC. Thanks |
Rotate motor to TDC and lock the cams to avoid a giant can-o worms that has devoured many motors.
https://www.youtube.com/watch?v=hAxj6FKMzvM#t=114
2009 Cayman PDK With a few tweaks 2021 Cayman GTS 4.0L 2021 Macan (dog hauler) Last edited by Cajundaddy; 02-22-2015 at 09:41 PM.. |
Accrochez-vous bien de vos rêves..........." |
Got an off line reply from Wayne -"Hi there. If the set screws are installed properly, they will lock the chain and the cams together. You do not need to lock the cams with the tool, but I do recommend that you remove the green plugs and check the cam timing when the procedure is done, "just in case". It's unlikely that a 5-chain motor will skip a tooth during this procedure, but if it were my car, I would check just to make sure".
Good enough for me. |
Schnell Gelb
I shall take no comfort in reading the disaster that probably follows. So cheap and easy to use the correct tool. So expensive if it moves while working on it w/o the cam locks.
here is a preview of the blood fest that may follow from this very Forum: can't rotate engine after IMS bearing change This may be of interest. Good photos porsche service boxster ims bearing repair install 986 diy tutorial Intermediate Shaft Bearing Replacement and Upgrade (IMS) Step by Step Replacement Guide - MIKE'S SPECIALTY AUTOMOTIVE SERVICE*Specializing in Porsche If you are a cheap skate ,it is easy to make the tool. But why? Buy from Pelican and resell when you are done. JFP - you have been endlessly patient on this subject. Before you get burned out, may I invite you to simply copy & paste this post to all other similar inquiries ? Question on IMS Bearing Replacement
2001 Boxster S Engineers muse Last edited by Scnell Gelb; 02-24-2015 at 04:48 PM.. |
Accrochez-vous bien de vos rêves..........." Last edited by JFP in PA; 02-24-2015 at 06:31 PM.. |
PCA Certified D.I.
IF it fits, it fits, if it hits, it hits. Buying somebody's tools does not guarantee you will do the job correctly anymore than making your own guarantees you will fail. To quote Dirty Harry, "a man's gotta know his limitations". Most important is understanding the procedure, the results of wrongly timed actions and knowing how to proceed cautiously and double check your own work.
I think there's a youtube video showing a man who can skin a deer in 2 minutes. It's about a 45 minute job for me, at minimum. To each his own. An ephiphany can occur to anyone at anytime, about anything. We just hope it's not after his engine is reduced to a smoldering pile of clanking scrap metal. Best wishes to you DHI1532
1986, '87,'88 928S4, 2006 Cayman S Cabluey, 2006 Cayman S "Burn Notice" |
Please don't be stupid. Crank to TDC and cam lock's in. Period. You really don't have to spend much time "googling" to find out this is the only way. Don't led ANYBODY tell you otherwise and don't play Russian roulette with your car.
