Radio turns on/off until car warms up
I have a 2000 Boxster with the standard CRD-220 radio. I have had the car for about 3 years.
When I first purchased, the radio would turn off and immediately back on about 1 minute or two after I first started the car. Then the radio would work perfectly for the rest of the day.
The problem has gotten much worse. Now, I have problems with the radio turning on/off multiple times and sometimes can't get it to turn on at all until the car is completely warmed up. 10/15 minutes of driving and the radio will work fine for the rest of the day.
Any ideas as to whether a problematic radio unit or some rely/short I should be attempting to chase down first?
Old 02-26-2015, 11:04 AM
Schnell Gelb
Check/replace with new Fuse D1 ,7.5A .
Check fuse holder/terminals for corrosion looseness.
Check manual for other radio-related fuses.
hit the TP function key (owners manual)
Do you have other symptoms - speaker connections,horn,alarm?
A major upgrade/modern generic replacement is cheap & has many more features.
Consider replacing the ignition switch- it is a VW part available here @ Pelican.It is a frequent failure point. Cheap and easy to replace.
Most important,if you do find & fix the fault,please tell us so we can improve our knowledge base.
Good Luck!
2001 Boxster S
Engineers muse
Old 02-26-2015, 08:48 PM
Another possible problem is the contacts on the removable faceplate. Cleaning them with an eraser has cured similar problems.
Old 02-27-2015, 06:45 AM
Tags
radio
