zaskar14 (guest)
Guest
Posts: n/a
To remove the tensioner pulley, when you say "backwards in orientation" do you turn the bolt clockwise to loosen?
This post was auto-generated based upon a question asked on our tech article page here:
Old 02-26-2015, 06:25 PM
You will hold the bolt with the 15 mm wrench behind the pulley, and you will loosen the 24 mm nut by turning it counter clockwise. Backwards in orientation means that the bolt goes through the pulley from the rear when compared to the other pulleys which have the bolts going through the front.
- Casey
