odometer light out 986 / 2000
m My odometer light went out two days ago. Checked all fuses and there good Any one have any ideas?
Old 03-20-2015, 04:35 PM
JFP in PA's Avatar
Yes, the bulb is burnt out; time for a replacement.
Accrochez-vous bien de vos rÍves..........."
Old 03-21-2015, 07:09 AM
The Odometer digital display on my 2002 Boxster S shows the bottom half of the miles driven number (less the last digit) and the top half of the Trip Odometer numbers. In addition, upon startup, the oil level display does not show. Is this caused by a burnt out LED bulb? I have no OBDII fault codes showing. Any ideas, Thank you
Old 09-10-2019, 12:40 PM
Administrator
Dmitry at Pelican Parts's Avatar
Check out this guide if you're going to be replacing the bulb - you're going to have to pull the cluster. Let us know if you have any other questions.
https://www.pelicanparts.com/techarticles/Boxster_Tech/102-ELEC-Instrument_Cluster_Bulb_Replacement/102-ELEC-Instrument_Cluster_Bulb_Replacement.htm
Old 09-10-2019, 01:11 PM
Administrator
That could possibly be the case - would you be able to post a photo?
Old 09-10-2019, 01:19 PM
2002 Boxster S Odometer Lignt Half Gone
First try at uploading image. If this did not work will try again
Old 09-11-2019, 09:11 AM
