Volume of brake lines in 2000 Boxster
I'm going to try a brake bleed for the first time this weekend. I have the Motive Pressure Bleeder and 6 bottles of 500 ml Motul RBS 600. I see there are several questions about how you know you've properly cycled out the old fluid. My questions is - what is the volume capacity of the brake system? Seems to me once you've pumped x ml of fluid through your system, you'd have a good idea you've cycled out the old fluid.
Old 03-27-2015, 04:18 AM
JFP in PA's Avatar
You should not need more than 1 liter to flush the entire system, clutch and brakes.
Accrochez-vous bien de vos rêves..........."
Old 03-27-2015, 05:10 AM
