Is it possible to replace timing chain tensioner without removing engine
Hello guys...
I have a plan of doing IMS and RMS... and meanwhile do some engine head work... I am thinking of taking of valve covers and replacing timing chain tensioners... Just wonder if it is possible with engine on the car... taking off the entire engine seems a little too much for me....I have never done that.... Thanks |
Do you mean the tensioning element that works the Variocam ,or the Tensioners? Significant difference in work involved.
Also wonder if the valve covers can be take off while engine on the car... Any ideas? |
I replaced the two rear tensioners in my 2004 with the engine in the car but gave up on the one under the air conditioner compressor. Not sure where the forth one would be located?
You need to lower the engine to get to the one under the air conditor compressor which entails removing the coolant hoses. |
I replaced my tensioners a year and a half ago with the engine in the car. It is a time consuming job, but straight forward, and the special tools make it a lot easier. Good luck!
David Nolen '99 Boxster '70 911 |
To change the tensioners, you will need a set of crank and cam shaft locking tools. To remove the cam covers, you will need the cam shaft retaining bars (a different tool); while all of this can be fabricated, you might be better off buying them (new or used) and then reselling them after you are done. If you are also planning on removing the cams or cam drives, you need yet another set of tools that is more year specific to reset the cam allocations when you reassemble the engine. |
Yuta,
How did you diagnose and confirm the chain tensioners need replacing? The plastic ramps/guides/pads usually deteriorate before the tensioners fail. |
| All times are GMT -8. The time now is 08:35 AM. |
