-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Wet Control Resolution (http://forums.pelicanparts.com/boxster-cayman-forum/85881-wet-control-resolution.html)
spzero 10-30-2002 04:32 PM
I finally got the car back from the dealer. Apparently the rear drains beneath the cover for the top were clogged, creating the overflow into the car. I give the germans a lot of credit for there engineering expertise, but this seems like a poorly designed system. If the drains clog, (it should be noted that my car certainly has not been subjected to any unusual circumstances to cause such an event) the water collects beneath the driver's seat which also houses the ignition controls, which must remain dry. There is also no drain benath the seat, so the water has no other option but to puddle and do as much damage as the precipitation allows. There oughta be a recall on this one.....
